Stop in for a cup of coffee
So, Lynda's youngest son Bin stayed overnight with us at my house. He is 10 years old and a cute kid and well behaved. I'm impressed. Then we went to breakfast and now we are at the cafe. I'm getting a lot of strange looks. LOL..kkkkkk
Bad bolt. Those are the ones that will twist in 2 pieces because the way the holes are drilled. The thick cork gasket goes on the other end after you insert the bolt in the adapter.
Thanks Mike and I have read about the weakness due to age/design in the little research I've had time to do so far. I saw an aftermarket heavy duty one, some mentioned elongated holes for higher flow. Engine builder told me I'd need which I knew I didn't have but his sidekick who owns and has worked on more Mopar mentioned a shorter filter which has also been mentioned to me, wonder about the filtering capacity of a shorter filter, maybe not a problem since seems some use.
FL300 Motorcraft and it's cross references is the shorty oil filter I used under the Hookers on the Swinger instead of the 90° adapter. The FL300 is only 4" tall rather than the 5.2" it's taller brothers are like LF1 or PH8A.
EDIT ... one of the fitments Motorcraft lists is '73 340 Dustpan :rolleyes:
Thanks Alex, appreciate the info!
Wix 51348 fits, its the small diameter short one. Used in many applications. I dont have room in the Fargo for a real filter. That being said, its about the same size that an LS uses. I change oil often enough i dont worry about it.
Thanks Frank, was wondering if a shortened oil change schedule was a good idea, would think so
TGIF, will be watching Saturday NFL tomorrow, just rewatched the Week 1 loss to the 9ers they found a way (Bosa). Seahawks will have #1 NFC seed with a win, fingers crossed. So weird to me the teams that are in the playoffs, Jacksonville, Texans, Broncos a Bradyless Patriots team etc. etc. Have a Good Night All!
