Yup... Been there...google is your friend here bud..
not familiar with the new LED tubes that work with the fluorescent ballast. the old magnetic ballasts needed all the bulbs in to work right, but with electronic, you may be able to put 2 bulbs in a 4 bulb fixture. With LEDs, that might still give more light than the 4 fluorescents. Any LEDs I have used are a different looking light, so I would just get a couple and try it...I think I know what to do, but was looking for other opinions/advise.. I have 20 4 bulb units, so 80 tubes. A Guy gave me a trash can full of T8 bulbs from a commercial building a few years ago. So i went in each unit then, and replaced the old style ballasts with a single electronic one. And then of course used the T8 bulbs. Butt they were used and many of them are out now. I have been told that I can use LED tubes that are compatable with those electronic ballasts. Or, I would have to remove all the ballasts and wire them direct, to use the other style of LED tubes ??
Heck.. If It'll work with the existing electronic ballasts, I will replace all 80 bulbs with LED. It'll look like you're standing under the Sun in here !!not familiar with the new LED tubes that work with the fluorescent ballast. the old magnetic ballasts needed all the bulbs in to work right, but with electronic, you may be able to put 2 bulbs in a 4 bulb fixture. With LEDs, that might still give more light than the 4 fluorescents. Any LEDs I have used are a different looking light, so I would just get a couple and try it...
Got it, ThanksI do know they have different shades like the fluorescents. I sent you his cell #
ROFL...Pg 26 now!
24&25 were long worded posts!ROFL...![]()
Me too!Dam your slow!
for sure - Dave put up what, two bulbs, and MAN what a difference!Heck.. If It'll work with the existing electronic ballasts, I will replace all 80 bulbs with LED. It'll look like you're standing under the Sun in here !!![]()
we'll be here............ does anyone else hear the theme music to Jeopardy...Pg 26 now!
Here is what I'm workin with...for sure - Dave put up what, two bulbs, and MAN what a difference!
What engine going in and whick k member you starting with? Mine was a slant went 440@halifaxhops, I ordered the Schumacher header and mount kit for the Duster yesterday,I noticed you used the kit yourself (pg24 or 25) Were you satisfied with it?
QA1 k member (v8) and a 440What engine going in and whick k member you starting with? Mine was a slant went 440
that's a well lit church compared to mine... what was it Keith called it a while back - the Garagemahal..Here is what I'm workin with...View attachment 1714954472
Cool I'll check that out. I've been told there is no place to put the torque strap on the QA1 so I'll have to fab something. Thanks for the input.Different from mine but very happy with it just do the heater motor mod if you ever plan on taking the pass valve cover off. There is a thread here on it. There headers are great also fit perfect. Not sure with a stick though.
