Stop in for a cup of coffee
I borrowed one from a local carb shop last year prior to gettin the eddy. I think it was a 3310, but cant recall. Im just tossing around the idea to have a 600 holley to go play with (like at the track) and use the 600 eddy, the rest of the year.
I've solved your problem. FAST EFI
we're a scary buncha clowns
Yes indeed!
Eddy 650 AVS Thunder. It's what I put on mine to replace that 600 that I gave you...:)
Alright, speaking of carbs. I have my eddy carb (Thanks Dave), but I also want to pick up a 600 Holley. The car sure does like that holley for the performance. I need vac secondaries w/electric choke preferred. Recommendations on which one????
Yes. the Holley 80457 600 vac secondary with electric choke, and it's calibrated for a late 60's early 70's engine...
Holley 4160 Aluminum Street Carburetor
I've always been told the numbers go to the back as well. I believe when I bought my PST bars, they also mentioned that in the instructions. Could have something to do with the clocking of the bars, but not sure.
When we installed the Just Suspension bars in our Valiant, they said that it didn't matter which side went front or rear, but once you use them, you have to keep them in that orientation afterwards... Just suspension has stars on one end and numbers on the other end of their 1.000" bars...
there should be a L & R on any torsion bar - OEM or aftermarket - I swear there was on the ones I put in the Scamp last year. Of course I had had them around for years and have no idea where I got them either. There is debate as to whether or not there is a back or a front - Torsion Bar Install
Chrysler used to use even or odd numbers to designate left or right...
heya Karl, ordered me some graduated cylinders and stuff from the link you provided. Seems they have flat rate shipping....
Yep, I ordered a few because of the shipping... :popcorn:
It helps to have a spare or two when you misplace one.... :BangHead:
Now try to find a small funnel, the one that I got from Bed Bath and Beyond, they don't carry any more....
If you need any help doing the calculations, let me know...
Just find the head volume of the combustion chamber (with a correct spark plug installed), the head gasket thickness and diameter of cylinder, and the bore and stroke of the engine, and how far the piston is from the top of the block at TDC...
