Stop in for a cup of coffee
I've solved your problem. FAST EFI
I was so close to buying the FITech, but opted out... Hard to justify spending $2500 or more on FAST....
Eddy 650 AVS Thunder. It's what I put on mine to replace that 600 that I gave you...:)
That is right I forgot that you where running that. I'll check one of those out as well.
Yes. the Holley 80457 600 vac secondary with electric choke, and it's calibrated for a late 60's early 70's engine...
Holley 4160 Aluminum Street Carburetor
Thanks Karl, I'll look into that one.
Nope, the part number goes to the rear I believe. There is also a L and R on the originals.
Well, I can confirm that the Mopar Performance torsion bars have the same numbers on both ends of each bar (plus an R or L to indicate which side they go on) and there is no apparent difference between each end. I put them side by side and flipped one and there was no change in the orientation of the end in either direction.
I am loving it ....got my bell housing from brewers performance today.
Expensive but worth it because this is a rare unit.
Mr. Wayne Brewer said it is heavy ...Holy cow he wasn't kidding, this is a heavy chunk of iron
Now I need to wrap it in pajama material and hug it while I sleep tonight ;)
I also like how you have named your wheels and written it on them...LOL!
HA!! Brenda was a car that is no longer with us.
EVERY car here has a name, and when one is parted....each part is marked so I know exactly where it came from.
I don't like comments like "yea, something like that" " I think its from that car, or maybe that one" .." I don't remember" comments like that get people kicked out of my shop because it either is or isn't and I like to track everything with log sheets, photos, filing and naming. LOL
Curiouser and Curiouser.
