Well as the saying goes. A bird in hand is worth.....
Two in the bush....
5 bucksI found a set of 426 Hemi rocker arms in my garage...
I gotta look them up and see what they are going for...
I don't have a 426 Hemi....![]()
Kinda high, I'm thinking....5 bucks
who Chris - yes he is!Kinda high, I'm thinking....
hehehehe - exactly!
nice! my favorite Ebay "trick" is to under cut the going rate by 10-15% - I get $$ and the buyer gets happy... win win
I don't think mine had anything on the straps and pretty sure I put them back that way. Original top was like really heavy roof tar paper. I glued 2 layers of EPDM roofing together to replace it.Was considering using a bicycle inner tube cut to size to replace the old rubber insulators on my fuel tank straps, any other ideas for that or for the top of the tank, other than ordering from a supplier like Classic?
But really for as much work as it was...If you don't already have the material, I'd probably buy one. What $ do they get for them?I don't think mine had anything on the straps and pretty sure I put them back that way. Original top was like really heavy roof tar paper. I glued 2 layers of EPDM roofing together to replace it.
MOPAR Fuel Tank Pad, Grommets, Seals - Fuel / Gas Tank Pad - Detroit Muscle Technologies, LLCWas considering using a bicycle inner tube cut to size to replace the old rubber insulators on my fuel tank straps, any other ideas for that or for the top of the tank, other than ordering from a supplier like Classic?
Thanks! I have a roll of the old roofing felt/tar that has an adhesive on one side. I think I can use it layered. I think I also have the original out in back still on the tank I can use as a template. I'll need to modify it a bit for the FI tank. Thanks for the input. Much appreciated!
I think there's more going on then just quarters, and inside the trunk had been re-sprayed at some point.
