its all your fault!
its all your fault!
Bet if the blower was made in VN you would break it out!Ehhh... I aint even gonna break out the blower... 42 tomorrow... I'll let it melt....
Hey I proudly represent that remark.9 Times your a worse sex addict then Wolfie!! I would have learned after the third or fourth time myself!![]()
To what?LOW screw in some plywood!
To what?View attachment 1715155688door post is flopping in the wind too. Wish i never agreed to it.
I have been lucky too. Usually measure old shims and install with new shims same thickness.DUDE !!! With a new ring and pinion set. You MUST verify the depth of the pinion , in the case, relative to the centerline of the ring carrier. Most pinions have this depth number stamped on the face. If you been doin it the way you say, you just been lucky....
The new pinion I just put in this Pontiac had to move .020 in order for it to be in the correct location. Would not know it unless I check with pinion depth tool...I have been lucky too. Usually measure old shims and install with new shims same thickness.
Looks like more than we've got up here.
You're allowed to change your mind. Worse than you thought - that's a lot of time if the pillar is floppin'To what?View attachment 1715155688door post is flopping in the wind too. Wish i never agreed to it.
They didn't wait for you to drive in before telling you?Figured that was happening...work officially cancelled for this evening as of about 20 minutes ago.
No, not today. LOL. That's OK. Boss is giving me half day pay for the couple hrs I was there yesterday.They didn't wait for you to drive in before telling you?
Ohio is covered....probably 6 inches. tired of this!You guys out east are getting hit again.
Could also compare numbers on old to new. And do the math. Dont get me wrong, yours is the correct way. And the best by any standards. Thats why you get to charge the big bucks...The new pinion I just put in this Pontiac had to move .020 in order for it to be in the correct location. Would not know it unless I check with pinion depth tool...
Yeah, it’s coming down pretty good right now...You guys out east are getting hit again.
