Stop in for a cup of coffee
Yea, she said you did, she is looking forward to seeing something she can buy from you :color:
I am sure there is stuff around here now that I know what she uses. Helps me get rid of stuff and get rid of my paypal balance since the brake episode. Got the vac pump late yesterday and the Mildon dipstick so should be on the road safely this weekend. Did you see if you have the pulley? I started cutting the third grove off the one I have Should drink a lot when doing that type of surgery. Fnd out the converter bolts were in but the transfer case was in N. Found that out when I mounted the shifter, did not even think of that one. The TT is getting there, slowly.
Morning all again ! Great day here cool night sunny day today and no so hot.
Same here 60 and sunny and highs hitting 78 to 80 degree's the last couple days Ray.
Enjoy this great weather bud :color:
Man #-o I am sorry :pale: I will get to that this day before noon ! I promise :glasses7:
Any one know what the hose between an upper and lower filler neck is called? I need one for the TT and cannot seem to be able to find it in the FSM.
The big one? The main one is a bypass hose? I thought that was like a vent, this is the main one that connects the two main tubes the size of a radiator hose.
Well, why didn't you say so? thats 'the big main tube connector hose' silly... LOL
Just did not know the name. When are you free to get the engine? Or if you want I can drop it off when the truck is running?
You know you need coffee when... It doesn't matter how bad the coffee is and you still drink it black. :coffee2::coffee2:
Been real busy, but starting next weekend things should loosen up a bit. Was really hoping to get up your way to see the 'new and improved' Pop. The truck option does sound better than shoe-horning it into the Magnum. If you do that I will have the hoist set in garage to pick it off. Easy peazy. No clue what Im doing with it after that...
Tell you what if the pop runs good for a few hundred I will throw it on the trailer and go for a ride. You want the 904 also? Could use a rebuild but runs ok. 106k on it as far as I know.
AND cold. That was me last night; needed some coffee after the manager gave the whole staff a lengthy brow-beating. Yeah that really improves morale and motivates people to do their best.
Just venting! Normal stuff for us working folks. I'm off today, yay! Rainy day here, that storm Erika is moving towards us, they say she's not strong, but she's a female, might be trouble, ha!
Yes, thank you. Actually, till the TT came along, i was thinking that would be a good run for the Pop. I hope its good for more than 3 stops though...
See what happens when she licks the empty's! Must be male ducks. Oh yeah they are! A duck for a .......
