Stop in for a cup of coffee
huh - it looks like bringing it closer to you with an adapter won't do much
Just sat in it and with the angle of the column it should help a lot if I can find one around 3" or so. Just looking on e bay they are not to bad around 15 or so. Pluss it will give the wire to the switches more room to wrap around in a turn.
I am just posting need therapy for it each morning I think!
You need group therapy....
I noted some changes I need to make when I drove the Swinger to Farmington and back. The seat/ wheel/ brake-gas pedals are all off for my liking. I have a stock 3 spoke wheel which is closer to me than I like. The flat rimblow wheel should be better when I get it redone. The seat is a flat bench that needs to be tipped backwards slightly and the original upholstery is starting to come apart. When I recover I'll have Joel replace the Jute with memory foam so that I will sink in when I set kind of like a bucket seat with the bolster sides if that's possible to do. The brake pedal is quite high off the floor. Too bad a shorter master cylinder rod couldn't be used to lower the pedal closer to the floor and still have enough stroke to stop the car. I might just leave it as is. Don't want to mess with safety! lol
it all seems so minor - until you dig in there and try to change it...
side topic, anyone know of a place online to buy silver coins?
anyone see the 82 year young guy on Americas got talent last night? 82-year-old retired aerospace engineer does Let the bodies hit the floor - - awesome!!
Karl how big is that box going to Anders now?
11 1/2" x 12 1/2" x 28" is what I'm trying to go with now... It's single layer corregated and I think I want to put an extra layer of cardboard on the bottom to help support the weight....
wow, that's the cheapest over spot I've seen thus far for silver rounds.
I was happy with them bougt a lot in 2009 and just been trying to put a full set together here and there when I see them. Some times jewlers that buy gold and silver have deals on coins usually 20x of face value.
