straightlinespeed
Sometimes I pretend to be normal
Mike, how is the car doing? Are you all up and running now?
boy, I hear that!! been looking at them... and drooling - LOLThinking I'm just gonna go efi
no truck yet - - kinda "fishing" you know?yea, I saw where you grabbed up that carb from Dave - I'm a little surprised really, I thought you dynoed out pretty dang good...
It is really good to get away from the car(s) sometimes.. clear your head and all that..
Yep, same here. Im really considering going with FiTech or the new one, that is supposed to give them a run, but I cant remember who that is.Thinking I'm just gonna go efi
Do you have a specific set-up in mind?Thinking I'm just gonna go efi
The 600 cfm shouldn't really change the dyno numbers any since all peak numbers came in at under 6k rpm.
It should just make it more efficient at lower rpm where the mpg numbers come from. The 750 is really just too big for that cam and especially at the 2000-4000 rpm range where mpg is determined.
You have some very good points there buddy. I guess I never thought of it that way.
I've been told that Im not going to like the Eddy carb from the Holley style that Im running. I think he was thinking on more of a performance aspect. Or he is just a Holley guy.
The funny thing is I had the exact same carb you hooked me up with on my car (318) when I bought it. I got rid of that carb because I was told I needed a bigger one for my 360. You have no idea how curious I am about going back to the Eddy.
Have you been following the FiTech thread? I started to, last time I read it a member was having some troubles with his.Fitech
I can't wait to see how you like it. Just be sure to set the idle mixture on both sides to the same number of turns from bottom (I don't remember where it was set for the hotter cam and single plane intake). 2.5-3.0 full turns out from bottom should be a good starting point.
The 360 pulls 625 cfm at 6000 rpm. Your dyno numbers hit peak HP at 5200 rpm which is 541 cfm. The 600 cfm carb should work perfectly once it's dialed in.
That's actually one of the great things about the Eddy carb. Idle mixture is really all you need to dial in with a mildly built engine. The metering rods and springs in the one I gave you are already optimized for the fuel flow you need for your build.Awww, the joys of learning to tune a different style carb all over again
Geez ... What's wrong with people? That witch burning mindset. That Lincoln is amazing!This is just sad. One of the guys I know got harassed off of a Lincoln Forum for putting a modern 6.4L Hemi drive train in his '62 Lincoln.
And now another guy got chased off a Javelin Forum for doing a build with a modern 5.7L Hemi drive train in a '74 Javelin.
like I said - jealous - g'morning allGeez ... What's wrong with people? That witch burning mindset. That Lincoln is amazing!
Good morning, everyone!
