Stop in for a cup of coffee
@MOPARMITCH is up early!! Carlisle count down is on
Yup , Just back reading. Gotta git started early today. Get the Ram on the lift and change engine oil and filter and fuel filter. Also heard a Popping noise on turns from under the front, while making turns. Need to check that out close , while its up. Then Vacuum, Wash, More organizing and gathering. May have to cut the lawn once more before blastoff.
ruhtroh - that don't sound good..
Good morning happy people. Rani, i hope the Dr has good news. Mitch, i hope the front end popping is a simple fix. Scampy, i hope the donuts turn our good. Keef, i hope you don't run into any issues today..
The front suspension is all new as of two years ago. But it is prone to strange noises since It is 2wd and I lifted the front to the Max ( 3in). I think spring bind or something like that. I do have to figure a way to modify upper control arms, since I out of camber adjustment. Cant get enough with the lift. Adjusted all the way out and still positive. Could be control arm bushings ( screaming for help )
Could be some custom UCAs in uour future...
Good morning coffee drinking! Mopar lov'en folks
Rainy ! I hope all is well girl I am in the dark so I will send out a prayer for this to be behind you very very soon and it will be just a memory.
