MomsDuster
Argo f*ck yourself!!(not you particularly - - just a knock knock I know)
Shimmy Shimmy KoKo Bop !!did ya read it? you can't put shims on these hoods..
I just re-read it... Makes perfect sense now.. I'm beginning to think that there's way too much blood in my alcohol system... I'm just not myself!!!did ya read it? you can't put shims on these hoods..
I have a pile of those shims - little U-shaped things squared in the outside corners, of varying thickness from about 3/16 down. They don't go in the hood latches. They go in the fenders, can go on just about any bolt that meeds 'em but generally turn up on the big ones in the top and back. If ya' didn't have any ya' could probly use 5/16 washers.did ya read it? you can't put shims on these hoods..
$12.95 free shipping on ebay.
Also know as Alignment shims.. Used Mostly on Chebbies and Furds....I have a pile of those shims - little U-shaped things squared in the outside corners, of varying thickness from about 3/16 down. They don't go in the hood latches. They go in the fenders, can go on just about any bolt that meeds 'em but generally turn up on the big ones in the top and back. If ya' didn't have any ya' could probly use 5/16 washers.
There was a previous discussion of that on here in 2014 -http://www.forabodiesonly.com/mopar/threads/hood-alignment.263048/did ya read it? you can't put shims on these hoods..
I used to think those shims were a GM thing only because I have seen GM cars built with ton of those and I never saw them on anything Chrysler. Then one day I was taking a low miles original valiant apart and there were ships like that on the rear fender stud, the one that you can only get the nut off with the door open.I have a pile of those shims - little U-shaped things squared in the outside corners, of varying thickness from about 3/16 down. They don't go in the hood latches. They go in the fenders, can go on just about any bolt that meeds 'em but generally turn up on the big ones in the top and back. If ya' didn't have any ya' could probly use 5/16 washers.
67 hoods are different than 68/9 hoods. he needed to keep the same hood hinges with the hood from the donor car.There was a previous discussion of that on here in 2014 -http://www.forabodiesonly.com/mopar/threads/hood-alignment.263048/
I am thinking they didn't use the shims on the assembly line, but when you had a car with that was misaligned the inspector would flag it and they sent cars with problems to a body shop at the factory to fix problems because they didn't have time to mess with stuff like that on the assembly line.I also have seen them, or something similar, on B Body cars, where the fender meets the cowl, on the back/top corner. I'm talking , unmolested cars...
I have seen 4 unmolested B body cars with shims in place already.I am thinking they didn't use the shims on the assembly line, but when you had a car with that was misaligned the inspector would flag it and they sent cars with problems to a body shop at the factory to fix problems because they didn't have time to mess with stuff like on the assembly line.
So I bet those shims came from the Chrysler body in house at the factory which is why so few cars have them in the big picture.
Shimmy, Shimmy, Koko , Bop !Shims? I like shims...
its possible all four saw the body shop in the factory, I would be interested to know if they had a lot of inspection marks, Like I have seen some cars with a grease pen mark on the radiator support or various places under hood to mark the car. My 72 swinger had a bunch of bright blue grease pen marksI have seen 4 unmolested B body cars with shims in place already.
No, whyRani, Do you Know how how to speak any Vietnamese at all ??
I wanted it pretty rocky 'cause I don't play a lot of leads though ya' gotta have riffs and I wanted it to do those in between big crash chords without needin' a lot of pedals and stuff, so I geared it pretty much for clear channel. Cool stuff about the ASAT electronics is, like the old Jaguars, ya' can isolate the pickups so there's a little delay between 'em and it sounds kinda like an electric 12-string. Play this song, it sounds about like this -too cool - I thought "slappy" was reserved for basses...
