zkx14
Duster De-ruster
I did...Do you have a For Sale sign on it?
1997 Neon 2door, under 114K miles 2.0SOHC automatic
Asking $1975
Dad bought it in Jan 2013 for $1495 109,474 miles
In that time over $2500 spent on it including:
1/13Rear brakes including cylinders and hoses and EGR transducer
3/13 rear struts and alignment
11/13 control arm bushings and alignment
2/13 Battery
7/14 front brakes and rotors
oil and filter done twice. last I know was 4/14 112,569
I changed 2 motor mounts, fuel lines, right front fender (corner was dented), clockspring (air bags and horn work correctly now), secured speakers in doors and fixed wiring, replaced missing vent covers and broken window crank. Properly attached door panels. Interior looks pretty good. Has covers on the buckets, but I think the only damage is left side of driver seat back. AC- tightened one fitting, leak checked, vac and charge. Trunk leaks fixed (side vent and brake light)
It looked rough with clear peeling. I did my best to make it look decent, but it does have numerous small dents dings and the paint is far from perfect. I did find a service note from 2013. Looks like they added antifreeze a couple times and questioned head gasket. I have not seen anything to say if there is in fact a problem. I have run it a number of times, but not inspected, so only driving I did was around my yard and a few laps around the trailer park before I brought it to my place. Tires look decent. I believe it should pass inspection without issue.
$1800
(I actually like the hood, lol)
