Just had to start him up there RAINI!
This is not wanking Wednesday
Ben!
Ben!
Ben!Or is it?Just had to start him up there RAINI!This is not wanking Wednesday
Ben!
And why not? I thought every Wednesday was!! If what you say is true, I've been doing this all wrong!This is not wanking Wednesday Ben!
what the... another one with sumtingwong!! that's three in two days... sheeshAnd why not? I thought every Wednesday was!! If what you say is true, I've been doing this all wrong!
and...you know, the 413 max wedge block i have, came from a mud floor in a barn....
its about a boat anchor. needs everything sleeved, even the cam bore(is that even possible?) and the mains boredand...
damn - you just aren't having any luck with engines huh...its about a boat anchor. needs everything sleeved, even the cam bore(is that even possible?) and the mains bored
no, this one i knew full well about. I'm saving it because of what it is. a true, by the numbers 413 max wedge block. I found everything but the heads and intake, we think the renter took those off and sold for scrap but couldnt lift the block so left it.damn - you just aren't having any luck with engines huh...![]()
thought about it, im actually thinking of building it one day. I've had it checked by a couple shops, they think they can fix it, but it'd cost about 3500-5000 to fully build.Make a table out of it.
lol, no. that one my buddy still thinks is worth a couple grand.That the one you offered me?![]()
Almost reasonable by engine build standards.thought about it, im actually thinking of building it one day. I've had it checked by a couple shops, they think they can fix it, but it'd cost about 3500-5000 to fully build.
that's just machining. that's not counting the parts like, intake and heads if I can locate them, sleeves is 120 a cylinder, plus the sleeve it's self, which is like 20 bucks a pop, line hone is 350-500 depending on the shop, magnuaflux, sonic check, shot peen, decking, lifter bore hones.Almost reasonable by engine build standards.
