Stop in for a cup of coffee
Have you figured out the correct angle yet. And don't cut it upside down.
I wasn't told about the angle needing cut until it was too late.... this is what happens when the wife decides SHE wants to build it but wants you to cut it for her and won't let you see the plans.... tell me to cut a 2x6 to 76 inches, I'm cutting it to 76 inches.....apparently it was suppose to have a 45 degree cut starting at 76 inches
And then tell them if they run around in the shower, they will get twice as wet and can save water by only needing to use half as much...
If they can rub their head and stomach at the same time, they can soap up faster....
Let them give you directions and they will say, "Turn right there..." as you pass the road that you're looking for... :BangHead: :elmer:
Letting her cut it may not be a good idea... :mad:
Didn't someone post something about Lorena Bobbitt a couple pages back.... :BangHead:
Won't let you see the plans??
Tear up your man card, it's just been revoked.
Bet she programs the gps. Or worse driving directions. Just mess in with you carry on.
Let me re phrase..... there are no plans. She's going off memory off something she seen on Pinterest
Then your man card is definitely revoked for letting her con you into this in the first place with no instructions/plans.... :mad:
(and we're not giving it back...) :mob:
And I'm going to contact Lorena Bobbit and tell her about you "so she can take care of business".... :poke:
Does she keep your balls in a jar on the shelf??? :wtf:
