Stop in for a cup of coffee
Trying to get in touch with Barry, no return calls, Have about two sheets I need to change when you walk into the house from water damage when the pipe leaked. Just a PIA for me to work overhead.
I'm sure I could help get that done, but prob not till May. As much as I need to get another job asap, I am hoping to have most of May off ( but not much more). Would like to bring the car up and paint it in that time...
Sure just let me know stay the weekend it should be doable.
I did look at the plugs Saturday. Much cleaner. I upped the gap to 40 and made sure the wires are all in cap tight. Did not get to drive it since. Want to see what that does and then prob look at timing again. Did you adjust the mixture?
How much resistance should wires have? I think they are supposed to be suppression? The ones I have on are, but checked set I took off and they had really low resistance stance...Book says OK up to 30K, but even the new ones are nowhere near that?
Suppression wire I believe are pretty high, forget what, yes I did adjust the mixture it should be fine. If you have a vac gauge get it as high as you can, then turn it in a bit. The timing should not have moved at all.
Good morning men. Just a hit and run before I get bounced.
Thanks Ray. I'm thinking maybe I should've cleaned off them pipes before installing. But nah.
I'm hesitant now, though. Maybe I should has OSB behind the drywall on the other side too. There might be shelves ...
And should I put insulation in there for sound dampening? 'cause now would be a good time ...
I try not to drink too much until I finish my round. Kinda affects my game...:realcrazy::realcrazy:
