Stop in for a cup of coffee
The guy that has this one for sale should have some receipts. His threads started when he bough the short block I believe and checked it out. +030 flat tops in the short block. (unknown) #596 heads which are hardened seats. Windage tray, Melling pump, new cam bearings, New ghain and gears, Summit 6901 cam and lifters. (218/228 @ .050 276/288 .441/.441 114°) Milidon 5 qt. pan. Edelbrock Performer RPM, ATI neutral balance flex plate. I did the math. If all true, $800 worth of goodies. Sounds too good to be true.
is this the one the guy is asking $1200 for and it will take $200 to ship? or the one more local? I totally agree with what Karl said, grab up a 360 and pop it in there! There is no replacement for displacement. Fair warning though - that's going to require some other changes and before you know it you'll be into for another $3k... shyt adds up quick. At the very least you'll find yourself considering a new TC and possibly a shift kit. Then the carburetor isn't quite doing it for you so hummmm, EFI? Hey, with all this power on tap, how about some more traction? Offset shackle kit and wider tires would be nice... maybe some steeper gears too. -- you know how it goes -- :D
Morning
It's the guy from here. Yes I was thinking that (I would need all sorts of other stuff to make it work)
appears I am first (at a reasonable hour) - - and coffee
You guys get up too early!
