Stop in for a cup of coffee
No idea then? Hey Chris burn the front tires off and the heat will loosen the drums!
Well, that should be an easy fix. Just undo the spindle nut and pull the drums off...hub and all. You can even grind off the shoe retainer pins on the back of the backing plates and have the brake shoes come off with it all.
I like the burn the tires off better myself it is cold out there!
Hey any of you clowns doing the secret Santa this year? I just signed up again! I actually hope Rick gets me, should be interesting.
Damn right it's cold! The car cover blew of the '66 and I just had to go out there and retrieve it and put it back on the car. Nearly froze my fingers off.
I just went on line and ordered a car cover strapping kit so I'm not doing this all winter. If that doesn't hold it, I'm going to put the stock wheels from the GTS on top of the cover on the hood and trunk.
They do suck in the wind. I had one for a 67 Camaro I had in HI it sucked every day, the reason for it was to keep the volcanic ash off of it, was not much every day but man it was acidic, cars rotted from the top down on the big island.
Wonder how much a rent a storage center is for the winter?
Dave can you put up one of those aluminum carports? Around here around 800 or so, no sides.
Zoning and neighborhood association won't allow it. Once I get past this winter and get the car back together and weather tight, I won't need to worry about it any more.
A friend of mine had a issue like that so the clown put casters on it so it could move! Nothing they could do about it, it is temporary!
Secret Santa:
I signed up a few years ago and I'll be damned but I think Ben likes Bourbon even more now. :rofl::poke::poke:
I think Keefer does now too. He took home what was left of the bottle you sent. :D
Dang, I was afraid of that. Sure the pot calling the kettle black. I am on my 2nd. shot of Revel Stoke! Another habit former!
Mine is galvanized-40x80.
The barn is 30x60.
Hay shed is 50x100.
All full with customers stuff for seasonal storage.
275 gets the whole winter indoor storage.for 275,better be heated.
The barn is 30x60.
Hay shed is 50x100.
Definitely a different part of the World than here. Heated car storage runs $500 a month here.
This time of year im full,all that is left is the snowbank. I should build an igloo around the dart...
Considering the portable garage is still on the trailer. Sunday.
