Stop in for a cup of coffee
Breakfast is up I made extra.
Ham and Swiss omelet with a side of Hasish Browns.
Bring your own coffee.
There are four on the outside of the load bank two are cracked. Prob will have to cut them down 5" is common but just scored a diamond blade for $10 for the Makita so I should be able to cut them now.
Use it yet?
Not yet...
I'm trying to get them to help finish assembling the 318...
Then we can start getting the station wagon ready for the engine to install... I have to find where I put the brake lines and master... I bought them years ago...
Now I have to decide if I want to keep the 10" drums in the front (They are all rebuild and ready to go), or change over to a KH disc set up... I have the KH disks and a master that will work with them.... I may keep the drums for the beginning since they are already installed, and keep the door open for the disc for a later time...
I see know what you're needing. Ceramic is the material of choice. You need something that is heat resistant. The smoke will roll at times from the heat that gets generated.
Is that standard hardware for that application.
I would thing molybenium .
I know it's expensive just suprised.
