Stop in for a cup of coffee
Feeling a tad better this morning.
A couple vitamin c tablets and it seems to be knocking this cold back.
Hope i can get truck finished early,and maybe get on the water for a couple hours.
The plan is, go fishing by the bridge,and observe the crane on the barge lifting massive beams into place.
Have FUN!!
The rv is kicking my *** no spark it appears to be. It started right up last month. Bet there is a wire chewed somewhere. Need to move it today before the gravel gets here. It is on a 2003 f350 ford frame. Any ideas? No engine light either and of course My scanner will not work on it either!
Fuel. Hear a pump run?
I’d pull a coil and stuff a plug in it to check for spark.
They pack a whallop,you would hear the snap.
Usually no fire and no code is a fuel supply issue.
Check for voltage at coils and injectors. Not with a test light,a voltmeter.
Ford eh ! do you have an extra brain for it, could have took a dump
You're on a roll this morning Ben.........................but which one?
I just have to tear into it I guess. I really need to get a book on it also. I don't even think I have a owners manual not sure. Be nice if it is a relay or something. It has sit for years but I usually start it every month and run it around the yard.
Sorry guys, didn't mean to make you sick before breakfast.
