not too bad. hard to passHow's 50 out that way now days?
Ride with @Mopar Tim and you can make it in 1/2 the timeWould love to check out the Nationals. Unfortunately it’s a bit more than a day/weekend jaunt for me.
Something like this.About the only pullers made for something that small are for Clutch pilot bearings. OTC had a couple available.He does fly when he is driving. Trying to find a internal bearing puller non slide hammer for 1/2" ID and at least 2" jaw depth. For under a million dollars. Prob going to have to make one!Something like this.
LaterHave a great day guys! Time to get ready.
I bet it does. Perfect size.Mike found out that a snap on battery terminal puller works great on reluctors.
Pilot bearing puller. Goes on a slide hammer.Mike found out that a snap on battery terminal puller works great on reluctors.
My favorite clutch pilot bearing/bushing puller is this bushing driver kit. Fill the cavity with grease find the size that fits snugly inside the bushing and give to a whack! Pops right out. And yes I fully expect a comment from Karl and/or Ben!About the only pullers made for something that small are for Clutch pilot bearings. OTC had a couple available.
Looks like a BD3142MA. LOLMy favorite clutch pilot bearing/bushing puller is this bushing driver kit. Fill the cavity with grease find the size that fits snugly inside the bushing and give to a whack! Pops right out. And yes I fully expect a comment from Karl and/or Ben!
Are they in the top of the housing under the breaker plate?Just been doing a lot of dual point bushings lately and been using a drift to knock them out really don't like doing that.
The bushings don't look like anything special unless its an odd size. Washers maybe...New oem bushings are not cheap if I have to take them out again.
NOS HEMI Mopar 65-71 DUAL POINT Distributor Bearing & washer 2585021 | eBay
Are they split for the oiler? Just curiousThey are pretty standard .5 ID .625 od and 1.24 length just have different slots for the oiler.
hey hoppy, you able to tune the dizzys for custom combos?
