Stop in for a cup of coffee
Stopped off for a little Mexican for lunch. Pics to follow.
Si...
Sitting in the Shop , watching Football. The GTS and the Cuda are side by side. I never realized it, and never checked Stats, but the 68 A body GTS is actually longer than the 70 Cuda...Never knew that........
Ok, someone check me.
i put the new starter in the Polara. I know one line from the positive of the battery goes to the starter itself. The Polara has a second line that goes up into the harness, does it go on the same terminal as the one from the battery or does it go to the terminal on the relay?
and no the wiring diagram doesn’t say or show
I’m drawing a complete blank at the moment
Starter relay...
I’m not surprised. The 74 dart I have is longer than my 64 B body bumper to bumper. It’s the width that’s much different
How bout Kirk Cousins ?? Wins in overtime against the Saints....On to the 40 Whiners.....Always liked Kirk, But the ownership here in DC doinked him...Good for Kirk...
I don't know, as I sit on my porcelain throne i browse fabo and ponder my own projects.
There was a time last summer I thought the coolest thing ever would be to go v8 with the valiant. I could imagine banging gears with a v8 screaming. I even bought early A v8 motor mounts which are becoming a very tough item to find these days.
I was cleaning my shed yesterday and ran into all the slant six stuff for that car and now I'm thinking I should just finish building the slant and try it out.
I have the slant to 4 speed bell housing (pretty rare part) and I have all the new bearings and gaskets for the slant ( just needs assembly)
Hmmmmm
I was suprised at length of my 69 barracuda. Scout fit in the garage with the motorcycle behind it. Barracuda takes up the whole space.. Scout seems huge but is really quite small.. Cuda has a huge ***!
I like big butts and I can not lie!
Hmmmmm
Put it together with what you have. 8f you get bored with it, upgrade stuff later. Driving projects are more fun than yard art! This I know for a fact.
I need to find an appropriate air cleaner and that's the last thing on the list.
An original air cleaner for that is extremely expensive.
So is the original style carb, I will just have to run my existing small Holley, and if I ever find a small cfm AFV/AVS type later.
