First time in many years i got stung by a wasp. Piss me off. Gonna fix them right away.
I would try a different shirt color, there is so much red in cars and lettering it is fighting with the orange. Perhaps a Sublime shirt? Hehehehe! See ya soon.We got a sample t shirt for our event. It's not too bad. it is more fun than the previous years shirts. The orange one is last year's. Comments? Your votes count.
Add fur and change the o to an i!I bet if we redefined "burger and tots" you'd change your tune...![]()
What’s th problem?Hmmm I’m not liking the way this is turning out
WELDING ??????What’s th problem?
Either that or he’s watching his soap operaWELDING ??????
Looks good from up top, crawled underneath and there’s some gaps between the panels, I should have butt welded everything instead of lap welded. Tempted to cut it all out and start over.What’s th problem?
Did you flange them?Looks good from up top, crawled underneath and there’s some gaps between the panels, I should have butt welded everything instead of lap welded. Tempted to cut it all out and start over.
Need pics...Looks good from up top, crawled underneath and there’s some gaps between the panels, I should have butt welded everything instead of lap welded. Tempted to cut it all out and start over.
YeahDid you flange them?
Hang on, I had to walk away from it I was so pissed.Need pics...
Penetration is good. I’m thinking the panel underneath is warping. That or the cleckos aren’t holding tight enough, might switch the screws and seeAnd if you aren’t Getting a good lap weld, you sure as fk don’t want to try butt welding!
That or my welding sucks or both hahaAnd if you aren’t Getting a good lap weld, you sure as fk don’t want to try butt welding!
Do I have to wear a mask when I shop online?
So
If ya use carb cleaner on wasps
Wasp spray on muggers
Do ya use pepper spray on carbs?![]()
