Somebody "needs" that cap. Good stuff. The box is worth more. LOLOccasionally I can still find these under 100, I save thiose for that guy!
That is cool stuff. Nice there is a market for your trash! LOLI have a ton of MOPAR boxes, I used to give them to Dave for his collage displays then one year at Carlisle I was selling just point boxes for $5 each empty. I don't really care I use the points anyhow. Some boxes get really pricey especially the early Mopar script ones.
That would be cool!Wolfie had a idea what to do with the trash distrib housings also have a ton of them was waiting for cast al to go up. Steampunk mopar lamps!
Sounds like it isn't getting power through the ALDL connector.. Is your reader self powered?Hey I got a question for whoever, 07 Cobalt started idling rough, pluged in the code reader wont even power up, tried it on another car reader fired up. The connector pins look fine any ideas? TJ?
Hey ChrisMorning
I agree, No cheapo HF, never had a issue before with it or the car. Just weird, have no idea if there is a fuse or anything if there is I cant find it in the Haynes wiring diagram.Sounds like it isn't getting power through the ALDL connector.. Is your reader self powered?
I have a couple of plastic 55 gal drums, I pump to from my oil drain device. There is an oil recycling co that comes and picks up the used oil for free, when I call them....Morning.
Cool outside this morning.
A few oil changes today,my truck, buddys pickup and his neices car and his wifes car. Forgot i have to deal with the used oil, my oil drain is full, plus the drum. So i hope i can drop it off today. And pick up an empty.
Check the fuse for the lighter/accessory charging port. Bet its blown. Powers the ECM readerHey I got a question for whoever, 07 Cobalt started idling rough, pluged in the code reader wont even power up, tried it on another car reader fired up. The connector pins look fine any ideas? TJ?
Check your power point fuse, thats usually what powers it. In the owners manual it would be the aldl fuse.Hey I got a question for whoever, 07 Cobalt started idling rough, pluged in the code reader wont even power up, tried it on another car reader fired up. The connector pins look fine any ideas? TJ?
No self diagnostics? I have never bothers to get a scanner, cause only had Mopars for many years that the dash gives the codes. According to what I read the dash on Neon can actually show codes most scanners wont. Had one last week for a 'misfire on cyl 4' Poped the plug wire off and back on. Battery cable same. No code since...I agree, No cheapo HF, never had a issue before with it or the car. Just weird, have no idea if there is a fuse or anything if there is I cant find it in the Haynes wiring diagram.
I guess you don,t read back either .....Check your power point fuse, thats usually what powers it. In the owners manual it would be the aldl fuse.
Honestly a monkey cant tune a holley. I know this for a fact. I cant...G'd Mornin wrenchers
