UGH!!!! I just ordered new rocker panels.... they wont be here until Nov 24th.....![]()
I know a place you can order electrical wiring and it will be there within a week....
We can't burn leaves but we do have a nice yard waste facility and we do compost by the semi load. We have all the equipment to grind, windrow, flip, grind and sift. The compost is free to the public. They were getting overloaded and thought they could sell it but the EPA said no because of all the noxious weed seeds that may still be in it. (apparently) But they were able to give it away to farmers as a soil amendment. The first spray of Round Up and any weeds will be gone. LOLThat sucks that they don't do that any more....
I think we need to cut off people's noses, or put plugs in them as it's causing us much inconvenience... Your city doesn't compost anymore and we can't burn leaves....
Hey, I just got an idea while typing this...
If we put air freshener in the masks that we have to wear in public for corona virus protection, then maybe we can get the cities to repeal the leaf burning and compost ordinances... That way the people who are sensitive to these things won't be troubled any more...
Then if they still complained, we could have chloroform laced masks for them and let them pass out in a corner somewhere every day so they won't bother us and society can move along....
snitches get stiches....Ok, we beat this guy up pretty good and he's following rules now...
Can we get a moderator to stop in there and clean up his for sale ad now??? Thanks...
[FOR SALE] - Edelbrock ld6b 340 6pack
whats the purpose of the gator blades?View attachment 1715625551
Mine have the high-lift type tabs on them, but are pretty flat otherwise
I had a Gator blade on my old Snapper push mower that worked real good.View attachment 1715625551
Already done Karl. Where you been? LOLOk, we beat this guy up pretty good and he's following rules now...
Was just looking for that myself...whats the purpose of the gator blades?
You must have been typing while I was cleaning.Good job Mike...![]()
i knew someone would say thatIn case you have alligators in your yard... Just run them sum bitches over and they're done... They are popular in Florida....![]()
i was wondering if it had to do with lifting the grass but that makes sense. i need a setWas just looking for that myself...
"Looking at the blade, you may think that the raised teeth are for cutting however, they don't cut the grass at all. The angle of the teeth is what produces those clean-cut mulching results. The teeth angle toward the center of the blade to redirect airflow and push the grass clippings back over the cutting edge of the mower blade repeatedly resulting in smaller and smaller clippings, giving you that high quality mulch. And because the teeth aren't used for cutting, you do not have to sharpen them and are able to sharpen the actual blade the same as you would with a standard blade."
Never used them. Not sure if they work right with side discharge, or if that should be covered to let them circulate the way that described it.i was wondering if it had to do with lifting the grass but that makes sense. i need a set
