Supposed to warm into the 70's here by Tuesday..
Good morning, switched from strong green tea to coffee this morningMorning Mike
Same stuff I used, still need some put behind bottom back seat. Looks good sir !!a bit done last night.. more mat showing up today hopefully.. gonna put a sheet or 2 inside the doors if it will stick.. maybe on the board between trunk and rear seat.. dunno yet
My bride had that stuff a few weeks ago. Her's lasted about two weeks. A friend of her's has had one for a month.Well to up date my friends here, I still have the crud, friggin head cold !! Tested negative for covid home test..
I am so over this !
Yep, same here, 80es by Thursday hereSupposed to warm into the 70's here by Tuesday..
Thanks.. and my lesson learned yesterday is that if you run your finger along the edge while putting it in... it will slice you open like a razor.. i ended up cleaning up blood while workingGood morning, switched from strong green tea to coffee this morning
did you go Keto?![]()
I hope my diet will get me out and moving in this great weather hopefully today (I don't think that will happen) or at least by Monday.. its been 5 days now.
I cut myself to, yep! It sure willThanks.. and my lesson learned yesterday is that if you run your finger along the edge while putting it in... it will slice you open like a razor.. i ended up cleaning up blood while working![]()
What the hell is Keto ?did you go Keto?
it's a diet... zero carbs.. was just curious.. i did it a few years ago and lost too much weight and had insane energy, felt like i was 18 again. You mentioned a diet and energy so i was just guessingWhat the hell is Keto ?
At 65 And 188lb 5'7" tall i could stand to loose ...ah... 15 lbs. Chicken noodle soup, fresh orange , banana and green tea, I am ready for a fried over medium egg and a slice of ham!! But I better waitit's a diet... zero carbs.. was just curious.. i did it a few years ago and lost too much weight and had insane energy, felt like i was 18 again. You mentioned a diet and energy so i was just guessing
Sounds good.. i'm 5'10" and 185 right now.. i need to drop 15ish myself.. I went from 230>146 on keto in 6 months and had energy like a puppy on speed.. i need to get back to it this spring.. i'm eating like a fat girl after a break up right now though..At 65 And 188lb 5'7" tall i could stand to loose ...ah... 15 lbs. Chicken noodle soup, fresh orange , banana and green tea, I am ready for a fried over medium egg and a slice of ham!! But I better wait
I will be able to prove it's my car with the 12k in performance parts to run low 13'sYou'll be able to prove it is your car because your DNA will be under the carpet![]()
Age ?Sounds good.. i'm 5'10" and 185 right now.. i need to drop 15ish myself.. I went from 230>146 on keto in 6 months and had energy like a puppy on speed.. i need to get back to it this spring.. i'm eating like a fat girl after a break up right now though..
No solid foods, no colored drinks, green hot tea, a little crown in my last night green tea, stretch my back backwards to relieve spine pressure 3 times a day because I seem to do nothing but sleep
I will be able to prove it's my car with the 12k in performance parts to run low 13's![]()
I have the same, love it.That's when you realize if your mattress is a good one for you or not
I went with a bed- in-a-box from Amazon... it's a gel coil hybrid. I like it.
And finally found a pillow that works for me as well.
Strategic pics is how i got screwed into my car... also not seeing it before buying.. #1 rule i tell everyone and i broke itWhy have people started taking these close up photos so you can't see the car? It's a thing now. Drives me nuts
Yes.. except shaped like a dart
