Stop in for a cup of coffee
1972 Dodge W300
Yup.. I use Waze. It will track speed and keep the phone screen active even without a destination plugged in
Work has a free app called Vessel View Mobile me and my boy use. Handy and has GPS speed in large numbers for a quick look
Mine has the housing and gear but no cable in my auto. I think the gear plugs the oil leak through the center.
Can anyone help confirm??
Do you have the factory spacer between the pump and pulley? Both my polys with iron pumps had a 1/4 inch spacer between the pulley and the flange of the water pump
The spacer goes between the pulley and the fan, not the pulley and water pump... The pulley goes directly to the water pump...
Hey Karl
Yes to all of the above
318 (1971)
Have an Early-A V8 radiator
Swapped in a cast iron water pump (driver side discharge)
Using the early timing chain cover with timing bracket (passenger side)
Water pump pulley is correct... seems the crank pulley I have is not
Yes, you have the correct water pump/fan pulley...
You need the correct crank pulley...
Do you have P/S or not???
