She had tube steak for dinner......Kkkkkkkkkk
I won't even waste a red X on that statement! How many cooling tubes do you see? A dozen x 2 ends?Nah. less chance of that than rubber lines
I found long ago that if you like lattes but not real fond of the foam, take that black aerator off the steam nozzle and let the steam do it's job. Minimal foam to get in your cookie dusterUpped the coffee game.
Did a test shot tonight... I'll need to learn the machine.
That black thing adds air bubbles and doesn't heat the milk as much, cooling off your adult beverage.
Rubber atf lines always leak. A double welded tube like that should have much less risk. Even if there are 24 of thenI won't even waste a red X on that statement! How many cooling tubes do you see? A dozen x 2 ends?
2 rubber hoses only have 4 ends. Use your head!
Almost fergot. Take some clean water in a cup of some sort and steam it after you steam the milk, helps to clean the bubble mechanism. Keep a box of teeth pix handy for cleaning that steam nozzle. Milk gets perty solid after being heated and left uncleaned. The tip cleaner for your oxy-acetelene torch will work too. Jet drills could be necessary in drastic sicheeashuns.Upped the coffee game.
Rain is coming here, right after Seahawks/Bengals game so prolly won't get much done outside today.Mornin gang...
Rain is supposed to be done... expecting sunshine might be a bit much...
Was poking around old parting out ads on this site, saw a 65 convertible, OMR had made an offer on it and you offered to help him get it out of there, something like 2 years ago, don't think it was Canadian model tho.Mornin gang...
Good excuse to get stuff done inside.Rain is coming here, right after Seahawks/Bengals game so prolly won't get much done outside today.
Hey Steph....Good morning everyone. Coffee has been poured. We are expecting sunshine today. Let’s hope. I’m done with the weekend rain.
That's better, I should do the same with used oil and hyd fluid, have a bit. Kraken are having a tough start for sure. Glad the Huskies beat the Ducks yesterday, hoping they can run the table.Good excuse to get stuff done inside.
Clearing out that old paint freed up some space.
Kraken are having a rocky start. Just rolled through the scores and standings.
The ad I read seemed like he wanted bellhousing or something then scrap, business I guess.There's been a couple that have come and gone. I think Wolfie has his build figured out now. It'll be very cool.
I had one that I almost had the guy convinced to just let me take it... fell through. I bet it ended up in the crusher
It was a good day. My son talked about it all evening and he passed out early. Good Memories are being made for him. That’s pricelessHey Steph....
Cool pictures from the shop yesterday
That the truck/rearend change, yes very cool!Hey Steph....
Morning fools and tools!
