Think yesterday I saw some crap headed your way, don't know how strong the storms but it looked pretty bigI doubt we will have any local snow. It was 57° at sunset and the same now and it didn't vary but 2° in either direction in between.
Looking at the radar, I think it's done with us for the time being. Farther south looks like it's getting soaked.Think yesterday I saw some crap headed your way, don't know how strong the storms but it looked pretty big
WOW!
Ouch! You OK?So...freezing fog apparently. In the ditch. Spun a 540⁰ and in I went. Wonderful. Just walked a couple miles home.
Holy Crap Eric, sorry to hear that!So...freezing fog apparently. In the ditch. Spun a 540⁰ and in I went. Wonderful. Just walked a couple miles home.
I am fine. Marie's truck is fine. Just stuck. It's 2wd. So, my 4wd is the one with the bad caliper to fix tonight, or add some fluid and pull myself out??? Then walk back to her truck???Ouch! You OK?
I'd do that if you can stay ahead of the fluid, if risky no sense making things worse/chancing it. Is vehicle in "safe" spot?I am fine. Marie's truck is fine. Just stuck. It's 2wd. So, my 4wd is the one with the bad caliper to fix tonight, or add some fluid and pull myself out??? Then walk back to her truck???
Pretty easy to mess up. Have to wreck a few before you figure it out.U joints and seals take patience, I've dinged a few seals for sure.
Gald you're ok. I also hit some black ice this morning, must be one of those magical Wisconsin morningsSo...freezing fog apparently. In the ditch. Spun a 540⁰ and in I went. Wonderful. Just walked a couple miles home.
Glad you're ok.So...freezing fog apparently. In the ditch. Spun a 540⁰ and in I went. Wonderful. Just walked a couple miles home.
You mean you’ve never done it that way?!?!FABO certainly is pretty unfriendly to people interested in restoration details. Sometime even just discussing how things were originally done.
Treed!
Today I went to install the U-joints and not only are the cross-shafts longer than the Spicer 1310 that came out, the yoke ears are sprung inward, one pretty visibly.
Parts store shop guy was actually pretty helpful. He thought heat was the only way it could be fixed without cracking. Of course someone at a sister shop hasn't returned his O-A set so he couldn't do it.
Now that may not seem helpful but knoweldge is - and my regualr mechanic may be able to do it or send me to someone.
The real insight was how he avoids this situtation. instead of using a press or clamp he puts the shaft in a vise and punch through the end cap and jeeps punching until the opposite end cap has moved. Then goes the other way.
My thinking is the books assume the joints will get regreased. But lets be real. Not likely when they are to the point they need replacing. Better off destroying the caps then getting in this bind. Counter guy told me this is the only place he's seen it done this way but makes sense to him too.
Well I slept at a Holiday in express last night and it is thong Thursday! Actually, on USAF Aircraft all rubber seals o rings etc. are dated and after ten years you toss them and also change them on the plane. Big PIA most basses don't do it.How do you know that worthless trivia?
Already have a pm going with him. Interesting question actually. Do not think there is a written answer to it. I think I know who might know the answer though. I get the restoration guys and try to help them out when I can. One of my good customers is getting his car judged this week by David Wise this week, not cheap. Found a ton of nos parts for him in the past. Some serious unobtainable stuff. Great example just found him the NOS wire from the e advance to the solenoid on the carburetor. I am in the wrong business!@halifaxhops
Decal question on ECU
Picture below is of a ECU decal I recently bought on line and 2 ecu I purchased from #halifaxhops. On my 72’ 340 Demon which side does the decal go? On the face side where the plug is on the left or the side the plug is on the right. My memory says the plug on the left. Decal is facing the...www.forabodiesonly.com
Where does the decal go question. Figure you'll provide a non-snarky response
Good luck on your welcome home beer tour! They will show you no mercy as they once again try and defy physics and drink you under the table!First bowl of Hu Tieu and also iced coffee this morning on the way to my city...
Last haircut I got at Exchange was done by a Viet girl, did a great job. Was mentioning you as having a place over there, she asked where and all I could think was the Delta lol! What is your town name?Some of you may be happy to know that I have cheated death once again. Actually twice. Two different flights. Now here in crazy Saigon on the way to my hometown, Vinh Long. Got to stop and buy some Beer..![]()
Ouch glad you’re okSo...freezing fog apparently. In the ditch. Spun a 540⁰ and in I went. Wonderful. Just walked a couple miles home.
Thank goodness you are ok.I am fine. Marie's truck is fine. Just stuck. It's 2wd. So, my 4wd is the one with the bad caliper to fix tonight, or add some fluid and pull myself out??? Then walk back to her truck???
