Looking and thinking more about it, I am assuming the wire is grounded from the tank to the frame.Hey Scott this is what I did. My tank is painted,so made a clip on the bare inlet and then grounded to the frame.View attachment 1716248266
The tanks needs to be grounded to the frame.I have the plug but I don't see where the ground is. Is the ground from the gauge back?
I will get about 150 miles per tank. Most of the legs are more then that...
Good work Fred !Got another happy customer with his new chin spoiler today. The guy figured out how to install it without my help. Good to see some educated people that know how to do something without reading the directions.![]()
Thanks Mike.Good work Fred !
You probably know there is a gasket under the pick up unit so even if you drill a hole in the edge of the gas tank getting a good ground is unlikey that is why I put it right on the pick up unit.Thank you Sir![]()
Yes Sir, I put the gasket on................I will make something like you did, what gauge wire is sufficient?You probably know there is a gasket under the pick up unit so even if you drill a hole in the edge of the gas tank getting a good ground is unlikey that is why I put it right on the pick up unit.
I used 14 AWG .Yes Sir, I put the gasket on................I will make something like you did, what gauge wire is sufficient?
Nice supper to watch the game with !
B's down early.Nice super to watch the game with !
Yep. I’m expecting 250-275 each day.I will get about 150 miles per tank. Most of the legs are more then that....
Hope so !B's down early.
I think they used up Swayman. Seems he's lost his MOJO
Thanks Mike!I used 14 AWG .
Hope it works out for you Scott.Thanks Mike!
I’m hoping to as well. I’ve never seen them but they’re supposedly gonna reach as far south as Alabama so I stand a chanxeSky looks like it is on fire. Might be able to see the northern lights tonight.View attachment 1716248315
To Panteras 13.. slow slow slow. ..3 shoots in the 1st period![]()
3 shots in the 1st period![]()
