Amazing Movie
Good luck at your appt., damaged soft tissue stuff or ?Morning. Off to physical therapy shortly for the latest LOD, vehicle roll over in June on drill. Injured my shoulder and my left leg and trying to get that all figured out now
came out yesterday in '93... someone posted it on twitter and the comment section was greatAmazing Movie
To make things flat like that I use a med honing stone. Cheap and works great. Need to re dress it hit it on a flat surface with course psa sandpaper on say glass.
When i took it off last night the last tube has a little twist in it when i loosened the bolts so i will prolly have to fix that, maybe cut the flange and straighten it out. Hoping to get away with the fat alum gaskets first.. Can't stand that 1 cyl header leak, reminds me of every 78 camaro everyone had when i was younger tick tick tick
As rough as every set of headers I've ever seen looks on the back side of the flange, it's a wonder they don't ALL leak![]()
We changed flange gasket after flange gasket and no help. We finally pulled the leaky side out of the van all the way to look it over. Just happened to glance down the collector
" Where the four primaries gathered in the collector, there was an unwelded gap between the tubes. Stuck the wire feed in there and squeezed the trigger and no more leak.
Don't forget your fall protection!Time to drive to Lake Cavanaugh and look at a router, oh boy. Have a Great Day All!
Since that dummass manager won't update the track's site. DirtFan.com . Looks like they may have bout every track in the country on there.
