Wife helped me bake a zucchini cake.
You going with acid dip?Is there any other way to do a restoration ???? Rear wiring, trunk lock hardware, fuel tank and associated parts all out today. Just have the shocks left to get off, some brackets underneath, and the fuel and brake line under the car. Thinking next week I can get it on a rollback and get it to the Stripper...
View attachment 1716285060View attachment 1716285061View attachment 1716285062
Yeah. I can separate the rods where they come down and go with an angled piece of maybe 14 gauge?yeah, they are just steel.. clean it up and patch a piece in, just don't go too hot it should be pretty thin
Be sure and set up some practice pieces to dial in your temp. Settings. Oddly enough sometimes welding that kind of stuff while counterintuitive setting just a bit hotter is actually better. That way you can hit it and get off super quick. You hang around and the whole thing turns to poo. (Where is Karl?)Hmm... Seat frame is roached where the bull rings go. I think I can clean it up and tack a piece in to replace it. Anyone tried that before?
Is it "weldable" material?
The car was definitely originally white though
Is there any other way to do a restoration ???? r...
No poo allowed...Be sure and set up some practice pieces to dial in your temp. Settings. Oddly enough sometimes welding that kind of stuff while counterintuitive setting just a bit hotter is actually better. That way you can hit it and get off super quick. You hang around and the whole thing turns to poo. (Where is Karl?)
check the thickness of the metal that's tehre and go with that.. 14 sounds too thick but i don't know the partYeah. I can separate the rods where they come down and go with an angled piece of maybe 14 gauge?
The area at the hump and the drivers side are good. I'll measure thosecheck the thickness of the metal that's tehre and go with that.. 14 sounds too thick but i don't know the part
16 gauge is actually right at 1/16th of an inch. 14 ga is a bit thicker! Not a lot of 14 ga in there but I am not familiar with your car? But I would guess @Icetech is correct 14 is like a welders dream, very thick. Remember welders and hookers have similar demands.The area at the hump and the drivers side are good. I'll measure those
No, I have a guy local that will media blast it. I'll take it to him on the rotisserie. He knows what he's doing, uses many different media's. He got started in Marine doing Boat bottoms mobily, after they were hauled out of water. Lot and Lots of Boats around here. 4 years ago , he built a huge building at his farm to blast in. He has done a lot of cars. I'll be sure that we discuss What Media is to be used.....You going with acid dip?
More heat
More rod
More money
Favor the 14 and push to the puddle to the thinner existing metal.Yeah. I can separate the rods where they come down and go with an angled piece of maybe 14 gauge?
i never thought bout it but 14ga would make **** sooo much easier16 gauge is actually right at 1/16th of an inch. 14 ga is a bit thicker! Not a lot of 14 ga in there but I am not familiar with your car? But I would guess @Icetech is correct 14 is like a welders dream, very thick. Remember welders and hookers have similar demands.
More heat
More rod
More money
I bet it tastes good. Your wife's a super cook.Sams sausage tonight and the wife's sauce. Man, that sounds dirty.
Hi Jackers... Back of that thing must've been 4 feet in the air. CoolJust look at these Antiques !!!!!!!
Got to wonder how long those were on this 70 Cuda. He probably had some big old wide tires on the back that wouldn't fit in the wheel wells..
Antiques !Just look at these Antiques !!!!!!!
They still work?Just look at these Antiques !!!!!!!
Dunno...I Aint usin Em.....They still work?
If they work how much.Dunno...I Aint usin Em.....
