Stop in for a cup of coffee
"I have a cunning plan"
Plan is to pick up some materials later today and mock things up. The metal on the base provides the base for the seat and a place for the hog rings to attach.
I'll look again, but not sure that riveting would do it, the who bit along the bottom is about to turn to dust. I just took a picture of the worst area.
Still thinking a piece of metal rod along the bottom for a solid base, and then an inverted L-shape bit of sheet metal tagged to that for the ring attachment holes.
I'll need to separate the vertical frame parts from the rusted area. I think a cutting wheel or multi-tool should be able to do that.
Before I remove any of the rusted stuff, I'll mock up what I think is the answer and see if it makes sense in reality.
More to follow.
wonder if Barry has that part he does seats. TA ALASKA? @ta alaska
I would never have thought of a bad ground.. that's interesting
I see it on the tester if it is painted alot then have to hold them by the base. Pretty crazy it will swing 360 if really bad. Points only. I actually wore out my clamp pads and had to replace them to get a bite again. Watch how many will say the clamp is the ground. Tried to dumb it down alot.
AlaskaTA? THe guy that has the Hamtramck site? He hasn't been on here for a couple years. I don't know what happened. Got tired of my s**t I guess!
I was wondering... I came up empty on the member search
Thought maybe I got lucky... But, NOPE
It is the opposite side... I think... Yeah. I could cut and scab. Maybe
Ooof... only 7k.. that pic of the drivers door striker tells a lot about that car...
Cuda the same?
naw, the 'cuda thing didn't start til 70.. the whole rear panel on that is off a 70.. i mean.. the car is nice but that kinda build is just i dunno... wrong to me.
I have a friend that's a cuda nut and goes off if someone calls a '69 or earlier a "Cuda" so of course i do it when i can :)
1/2 the price and about the same shape
First ‘Cuda’ 1969
"Cuda" did start in 69. It was a sub model of the Formula S
I love on the '64 how they didn't even try to make the dash nice.. just.. make a box ande put some holes in it.. done! :)
