So today started with Debby,and now grandmas buttered muffins with tuna…….
Could be worse Pete we could be talking about Deb's buttered muffins that smell like Tuna.Never mind just first thing that popped in my head.
Could be worse Pete we could be talking about Deb's buttered muffins that smell like Tuna.Could be worse Pete we could be talking about Deb's buttered muffins that smell like Tuna.
Wish you were closer I'd come over I have everything to try out on your car.will order some of that an try it
No...no.. That never happensO-K, back to our regular scheduled program
This is the regular schedule.O-K, back to our regular scheduled program
Needed more!Cracker soup ?
Yes sir!!!Needed more!
Oh, crap...I did just learn that if you spill gas on this single stage the paint wipes right offi need to get a better funnel
I promise to do better next time.Yes sir!!!![]()
naw, in a spot you can't see, already fixed itOh, crap...
What type of single stage paint are you using, and did you use a hardener in the paint?I did just learn that if you spill gas on this single stage the paint wipes right offi need to get a better funnel
WD 40. Removes Rustoleum paint. Good hand cleaner.Oh, crap...
My wife laughs at me cause I have red crackers in a soup bowl.I promise to do better next time.
I have to buy another family size box.![]()
Not trying think you're doing anything wrong just trying to help.What type of single stage paint are you using, and did you use a hardener in the paint?
Stop being so humble Fred. You're genius on this stuff.Not trying think you're doing anything wrong just trying to help.
i bought it from vintagepaint.. it's **** but it was also not super expensive, it goes on ok but if you hit it with any caustic it comes off.. maybe a longer cure would be better. BUT at 90 a quart with hardener i'll use it over 250 a quart other places wantWhat type of single stage paint are you using, and did you use a hardener in the paint?
Thanks Chris but not all that good.Stop being so humble Fred. You're genius on this stuff.
Because tomato soup is yummy any time.I know it's 96 degrees here and why am I having Tomato Soup.
Butter on the outside, and just a little mayo on the inside.Key question....
Grilled cheese.. .Butter the bread (all sides) or not?
It's actually kind of a trick question. Actually, it's not a question..more a mandate![]()
errrrr....Butter on the outside, and just a little mayo on the inside.
Ok Just my thoughts on that paint and I could be wrong but it takes 6 months for cheap paint to cure, and keep it if I were you from any chemical and whatever you do don't wax it for at least 8 months or try buffing on it.i bought it from vintagepaint.. it's **** but it was also not super expensive, it goes on ok but if you hit it with any caustic it comes off.. maybe a longer cure would be better. BUT at 90 a quart with hardener i'll use it over 250 a quart other places want
