There's the interior...
Smidge of debris in there, Eh?
Lucky me, my original gas tank in my 73 Scamp is in good shape. Looks like the same as yours and if it's off center a bit it's going to be a pain to keep it from spilling gas or fumes if you can't get it close to specks.
Never go in dry. Lube is your friend.Finally got the right distributor for the 59 Apache pickup last night and installed it this morning. I now have oil pressure and it seems to run good. Had to beat the **** out of it to get it in the hole.
Hope it will be picked up tomorrow so I can clean my garage before winter sets in.
Yep that's what I did but was still tight.Never go in dry. Lube is your friend.
I'm on it.Been bent over a fender all morning and I'm sore. Getting old is no fun but the good thing is I'm retired and I can poor me a drink early.
Cheers my friends....
That's what she said. Damn where has @krazykuda been?Been bent over a fender all morning and I'm sore.
You mean at the fill neck?They are tricky to get sealed when correct. Just sayin'
Cheers Mike.I'm on it.
Then by all means marry it!Yep that's what I did but was still tight.![]()
Yes, where the fill neck goes into the tank. It has to be close to perfect alignment or you will leak gas out when you fill it up and drive. New rubber seals may help. Or not.You mean at the fill neck?
Agreed!
Think I should think about what I post before I post it.
I have seen so many good vids on Facebook of the game last night. They were on fire.Agreed!
Man o man #22 is lighting it up. I think they have a legitimate shot at making the playoffs.
Yep ... She tends to unleash so far out that the defense gets caught off guard
She is making the whole team better they double team her and she sends it to the open man. They just crushed it last night.I have seen so many good vids on Facebook of the game last night. They were on fire.
Damn!Power keeps dropping in and out... Gave up on being under the car.
Rain coming down at about an inch and a quarter per hour.
You're coming out? What?Well. Trans has to come out. Front seal leaking...making noise in neutral. Only leaking g in neutral.
