Intermediate cable? Not sure what you mean by that HopIs it hooked to the intermediate cable? Seen those to short in the past. Should have gone with @mobileparts
That's where the fistfight is taking place. Runs from the fixed points off the wheels, and hooks up to the cable assembly that comes out of the passenger compartment. Both drums are set and seem fine, and running the new one from the ebrake lever to the cross member was fine. It's the long cable that connects it all together.The cable that runs to both sices and hooks up to those cables. Usually just wire rope
That sucks screwed me up a few time. They are getting busy so I bet some mail will travel the country again!Good morning everyone. 30⁰ today. My parts for Friday look like they will be late. Grrrr
Yup that one. Actually, Sent Tim a swedge., that's how we got to know each other. Think the Cuda one will fit?That's where the fistfight is taking place. Runs from the fixed points off the wheels, and hooks up to the cable assembly that comes out of the passenger compartment. Both drums are set and seem fine, and running the new one from the ebrake lever to the cross member was fine. It's the long cable that connects it all together.
Lemme get my coffee going and I'll go grab a picture
If you have your old cables double check the length of the new ones
I was thinking about just going to the hardware store, getting a length of cable and swaging it myselfYup that one. Think the Cuda one will fit?
you can't pull the ebrake arm forward enough to get it on? i am trying to find a pic of mine but it was right around where your cable is when installedDouble checked those last night. Same length. Which leads me to thing that the cable assembly coming from the ebrake lever is the culprit. The threaded rod where the cable bracket is connected.
you will never get it gone well enough to hold... i have never used the ebrake though but good to be safeI was thinking about just going to the hardware store, getting a length of cable and swaging it myself
I actually ran a ratchet strap from the center of the cable to the K frame at one point trying to stretch things out. Can't get the damn nut on the threaded rod when I did that though. It pulls at a weird angle.you can't pull the ebrake arm forward enough to get it on? i am trying to find a pic of mine but it was right around where your cable is when installed
I have cable if needed left over from the hops trellises. Not sure if I have any round swedges leftI was thinking about just going to the hardware store, getting a length of cable and swaging it myself
It does take alot to swedge it my tool looks like a large bolt cutter.you will never get it gone well enough to hold... i have never used the ebrake though but good to be safe
Umm.. wasn't gonna mention this.. but all of my test driving so far (20miles) i had the ebrake on... which means 2 things.. i suck.. and the ebrake is ****Stupid question the e brake in the car off? I have done that stuff!
Yes.Stupid question the e brake in the car off? I have done that stuff!
