Stop in for a cup of coffee
2. Setting the base adjustment
Remove kickdown linkage from carburetor: Disconnect the kickdown linkage rod or cable from the
carburetor throttle lever.
Manual wide open throttle (WOT): Push the accelerator pedal to the floor, manually holding the
throttle open to its wide-open throttle (WOT) position.
Adjust linkage at transmission end: With the throttle held at WOT, push the kickdown linkage rod or
cable all the way back towards the transmission until it stops.
Slide t the rod onto the throttle stud: While still holding the throttle at WOT and the linkage pusihed
back, the linkage adjustment rod or cable end should slide onto the throttle lever stud with
approximately 1,/16th of an inch of clearance, without any binding or being forced into position.
Adjust if needed : If the fit is too tight or loose, adjust the length of the kickdown linkage rod using
the adjustrent mechanism (e.g-, screwing a slotted adjustment bar in or out) until the desired
1/16th inch clearance is achieved
Release throtle and reinstall linkage: Release the throttle, then reinstall the kickdown Iinkage and
any return springs
3. Fine-tuning and testing
@lkopaska
Is this correct steps??
Perhaps. But I really think the carb needs to come of and be looked at....Thought that last I saw it....
Without the cable and kickdown attached it acted well. With just the cable it stuck a little, so I increased tension on the spring
With the modified bracket and adapter on it is behaving much better. The idle screw is turned down a bunch from where we had it, Mitch
Is the transmission upshifting yet ? Did you drive it after the mods ?
Fingers Crossed for sure friend......
I'll give it a go in the morning. Nearing dark now.
Here's the difference in kickdown length.. about 8 threads shorter
