Stop in for a cup of coffee
What the heck.
Not sure. I remember a few years back someone was unknowingly dragging a chain down the road. Could have been a trailer safety chain or a chain that came loose from a binder. Regardless, it was sparking as it bounced on the road and started a whole bunch of brush fires over several miles!!!
Ok, crew.
Had an issue with the throttle cable. Think i got that figured out.
Is it a "thing" to need a stronger return springs?
I don't know if this applies to the rear pump transmissions but would think the concept applies to them just the same.
Is this what you have?
New life on the farm! Had our first two litters of bunnies last night and this morning. Both does first litters so not expecting much. Looks like 3 live kits from each one so far. One had a stilborn kit and then must have delivered two more after dark. Unfortunately they weren’t in the nesting box so they didn’t make it.
That’s crazy
This covers my belly on Victoria, tuff stuff for sure. Ok, just realized I haven't did any exercises with my side arm in ......ah..... seems like First of February, after the tank, lines and carb changes are done it's going on my to do list.. wow what a fast spring and I would say summer, but it's not over yet.
Tank strap? That undercoat can be a booger to get off. The heat gun does help. Don't use your wife's hair dryer. You'll burn it up and then you'll be in trouble. :mob: :rofl:
You know my sugar britches all to well lmao lol, slapping my nea
Spent all day yesterday digging nearly 700 feet of water line, 4 feet deep. Getting thru the roots in the woods and the hard packed clay was a pita. Surprising the ground is much much dryer than one would think for the extremely wet summer and spring we’ve had.
Water line around here is 7 to 8 feet deep.
I raised New Zealand Whites as a kid. I butchered them for sale. I sure didn't like the squealing when I cut their heads off. I'm too kind hearted for that. I did win some purple ribbons at the 4-H fair a couple years.
Hey Matt
Thanks for looking
No, it's the early 64, V8 setup with the plate mounted to the head
They didn't have a slotted arm but the adjustment was on top. It's interesting that a simple cable replaced all that in years following. Think of the simplicity and the cost savings. Like the GM trannys with the push button adjustment. Plastic and cheap, simple and effective.
Never knew this Chief, durocks kepth the fairoing..crates busy on a farm up in Illinois busy, I don't miss that job, cutting teeth and nuts out..oh my !! Our younger days
