storing for the winter
GO DART
overland park, ks
we've enjoyed a warm winter so far but the darts sitting under cover in the gararge with 1/2 tank of gas. she's gonna sit for 5 maybe 6 wks. should i
add stabilizer to the gas?
should it be started and idled ocassionally?
Add the stabilizer to the gas, maybe tape over the exhaust tips so no little critters get in the pipes. As for starting it if you do make sure it runs long enought to get to opersting temp to burn the moisture out of the pipes. Otherwise dont start it. If its going to sit without running you may want to get a oil pump priming rod to prime the system before re firing it.
Thats what Ive done, mostly bevause I miss hearing the car run after a few days.
