Kikowillers
Hello,
So today I was testing my Dart's lights with the engine off, and when testing the blinkers (turning signals), the following happened:
1) Left blinkers worked fine
2) Right blinkers turned on and remained on, no blinking whatsoever
I thought that was strange and I knew the blinkers had worked earlier on when the engine was running, so I turned the engine on to test it.
And as predicted, with the engine on the right blinkers worked again (??). However, they seem to blink slower than the left side.
Does anybody know what could be causing this? Any help is appreciated.
Cheers!
Cheers!
