MOPARJ
What can I upgrade now?
Almost sounds like piston slap.
Too squeaky and inconsistent. I think I am going to swap to my spare distributor tomorrow and see what happens.
I must be hearing something different.
Almost sounds like a couple keys jangling together. If there is nothing under the dash rattling around, and the pipes aren't banging around against the hangers or something then I would spray a little water on the belts and pulleys and such. If that doesn't quiet it down then it would be time for a stethoscope.
Also, there is a short period where it sounds like there could be some piston slap going on, but that isn't the noise your talking about.
Alternators have been known to make those strange erratic noises also.
I had a water pump damaged in a car/deer altercation with just enough damage to cause it to squeak for 40,000 miles before I finally tired of the noise and changed it out.
I know you seem to think the sound originates from the rear, but sound is a wave and the fan can blow it around, other sounds can interfere, and an engine compartment is like a tin can so it will echo all over the place.
Are you talking about that REALLY high pitched sound? More like a squeak? That's metal on metal. It'll turn up sooner or later. lol
I have heard throw out bearings and pilot bushings do that if they were dry, but usually, you can tell a difference when you depress the clutch pedal.
Have you tried feeling the oil pan for maybe a windage tray rattle?Or the oil pick-up fell down onto the pan?
But yeah, I watched the video with headphones on about 8 times before the odd noise kindof made itself known.Then I listened a buncha more times.
If you were to rev it up and shut it down at a higher rpm would it continue to make the sound until the engine ramped down? That is enough noise that you should easily be able to find it with a stethoscope.
If there is any slight angle between the pickup and pan (which is pretty much always the case), it will pickup fine.Thought about the pickup but wouldn't oil pressure be way down?
Shut it down at 1700 rpm and heard the noise spool down with the engine as it ramped down
So was it any easier to discern where the noise originates from without all the exhaust racket? If it is in the back there are not many options. Flywheel rubbing on something maybe. If it is inside the block I guess you could go for it and use the hope for the best method. Most any idea I could come up with now would border on speculation. Maybe the camshaft is working its way out the back of the block. Probably not if the distributor is ok. I'm mostly at a loss right now. Locate the noise and you will more than likely have it figured out.
Just wondering if you have pulled off the alternator belt and run it for a bit to see if this goes away?
