killnine
So I finally got a piston stop tool and spent some time today verifying TDC, since I've never been 100% sure. I rotated it around both ways, marked things, found the middle, and it was where TDC was marked on the balancer. I made sure this matched with the valves being closed and the rockers loose.
Here's the problem. If I put the rotor in pointing to #1 at this point, it will barely try to fire, and will be way too retarded. Even if I adjust it to where the distributor is able to be advanced as far as it will go, it's still not enough. I have to take the distributor out, move the rotor one tooth advanced, and put it back in. Then, I can start it, etc. The timing light at this point will show it at about 12 degrees or so advanced, and that or a little more is where I leave it and it runs fine.
So of course at this point the rotor at TDC is basically almost pointing to the #4 or whatever next plug is in the cap.
My worry is that this is a sign of something that needs to be resolved otherwise. Like a cam timing issue or something.
I would not be surprised if the PO did something weird when installing the cam/chain/gears. He also had the firing order one forward on the distributor cap to resolve this issue. That would be another way to deal with it, but it's obviously still a problem.
