Stroker engine thinking
dodgedifferent2
southwestern, Ontario
So I have a 340 with a 4 inch stroke
4.08 bore with icon ic745 dished pistons. 20.5cc
I have indy 360-1 heads ported already. 1.6 ratio rockers
Chambers measure 62 cc
Pistons measure .058 down in the hole. (Machine shop messed up)
I have a .027 head gasket with 4.125 bore.
I got a camshaft already. Lunati Part Number: 40200734
  • Advertised Duration (Int/Exh): 285/293
  • Duration @ .050 (Int/Exh): 255/263
  • Gross Valve Lift (Int/Exh): .600/.600
  • LSA/ICL: 110/10
  • Abdc 51.5
I measure static compression at 9.4
And dynamic at 8.1
I wanted my compression at 10.5 with aluminum heads and run pump gas (91 octane)
Will this work out?
I keep cycling back to going flatop pistons icon 744 with 5 cc but I would need thick gaskets of .08 but i would lose quench. And be at 11.0 stati compression
Equals 9.5 dynamic.
I want to keep pump gas but I don't want to be disappointed either. I had w2 before the indy head swap
How are you measuring dynamic? That sounds really high for such a low static and that much duration. I suspect the intake closing event probably corresponds with the duration. How late is it?
I bet your cam card timing is at .050. Using the Wallace calculators, I have your IVC @ 68.5. So you dynamic is 7.40.
Seems to me, if you substitute the 744 piston and a .039 gasket, you'll be around 10.7 with dynamic of about 8.35.
But, I've been wrong before.
Are you sure your measuring your piston below the deck correctly? With a comp dist of 1.465 and a 6.123 rod and 1/2 stroke of 4.00 you've got 9.588 combined. This to me should of been less than the .058 you say you have. Maybe give it another go with the measurement.
I zeroed a dial indicator on the deck and moved it to the rim on the piston.
Of course piston was at tdc.
Measured .058
With the Flattop the piston was a zero deck
That is a "step-dish" piston. measure to the flat portion of the piston closest to the center of the engine, the full 20.5 cc of dish volume takes into account the "bowl" and including the rim of that bowl to get the 20.5 cc's of volume. Where is the "flat" of the piston in relation to the deck?
  • LSA/ICL: 110/10
  • Abdc 51.5
And dynamic at 8.1
Will this work out?
Equals 9.5 dynamic.
Just FYI
In my 367,I have run Scrs of 10.9 to 11.24, with Dcrs of up to 8.8, and cylinder pressure of up to 190, all with aluminum heads, all on Manitoba 87E10 and for many years; so I like your plan. I ran Q of .039 to as little as .028. Currently at .034, since 2004.
That's looking to be a wicked engine.
From the rim not the pad.
The pad may have to be machined off to set the Q.
But the volume of the Q-pad, after it has been milled, will need to be figured into the equation to determine the Scr.
The volume of the dish has been given, but there is no accurate way to determine the volume of the finished pad by itself, so you will have to use the .500 down fill-volume method.
But be of good cheer, the uncut volume of that pad is likely only between 1.5 and at most 2.5cc
The rim will need to be at the deck for 10.4Scr, I think
With an .027 gasket, that Q-pad needs to end up just below the surface of the deck about .013, for Q of .040, But if the rim is at the deck, you'll just cut the pad flush to the piston rim for a Q= gasket thickness, or .027 in this case. Or increase the gasket thickness by the amount of the pop-up.
If the Scr works out to 10.4, then with than ICA of 71*,the Dcr works out to 7.9@158 psi, great for iron heads.
How did I get an ICA of 71*? I averaged the durations and subtracted twice the LSA to find the overlap,which came to 69*. I gave half of it, 34*, to the intake , and determined the ICL to be 108.5. This fixes the ICA at 71*. That's a heck of a cam.
Looking at that piston, I'm guessing to make 20cc in the dish, that it would need to be about .085 deep or more. If you measured it at .057, then the rim must have been above the deck, some estimated .028 inch; and that would all have to all come off, to make room for that .027 gasket..... .or a gasket at least .028 thicker chosen. Or some combination.
But for aluminum heads, this is not the way I would do it; I like my 185 psi. But then if I had a stroker, on the street, even at 158psi, the bottom end is already stronger than most chassis will be able to handle, and the bonus is it will burn almost any old crap gas.
But; to get 180psi, you would need to get the Scr up to around 11.5 for a Dcr of 8.7@179psi. And that's where the problem is . Your swept is 857cc, and to get 11.5, you would need a TOTAL chamber volume of just 81.6cc. You can make about 76cc with an .039 gasket, but the FLAT tops would need to be down a bit, depending on the volume of the eyebrows. It would be very easy to have too much compression. I'd estimate about .030 down. But this makes the Q to be .069, so it is as you said .
The tops of those flat-tops would need some custom milling, to leave a Q-pad up near the deck. 180psi would make a killer bottom end, certainly more than any streeter could likely handle, and would be waaay overkill. So
A little less cylinder pressure would be fine. The trouble is ,with flat-tops, how to get it; you'd have to sink the pistons even further.
I feel your pain.
IMO, the dished pistons would be the way to go, but less cam would pump up the cylinder pressure. Unfortunately even 170psi, would take a LOT less cam, at 64* ICA. That's 7* less on each end so about 270 intake duration. And the bottom end would be ludicrously strong, posting a VP of 168.
If you really want to run that very large cam, AND aluminum heads, AND make the big pressure, I guess the best solution is to order custom pistons, with the correct compression distance, the correct Q-pad height, and the correct dish volume. They're not that much more money, are they? And think of all the machining costs you'll save.
But that's a heck of a cam.
I suppose you could compromise with a little less duration AND a tighter LSA, and sacrifice some overlap. The math says a 274* cam, with an LSA of 106 and installed straight up would have an ICA of 63* , close enough. This could be had with 65* of overlap. And, as a solid flat tappet, at maybe 235*@.050... Mr Wallace says Scr of 10.4/8.45 Dcr./172psi and a whopping 171VP
Decisions, decisions.....
But before I would get too excited, I would revisit the deck height, this time measuring to the rim,not the pad and not the bottom of the dish. Ideally it will be at or above the deck.
Does this look like your dished piston?
I hate to be a bother about this pistons calculations. BUT this is a unique situation with the compression distance calculation, 1.465 IS measured to the upper most part of this piston. The piston will only measure 1.415 from pin center to the "rim" if you measure it that way! From the outer rim of the bowl to the quench flat is a .050 measured height and from the outer rim into the bowl is a measured .100 thou. The full 20.5 volume is achieved because of this bizzar combo of the pistons shape. Using your calculation then puts this piston at .008 thou below the deck.
If you need technical support call UE+M at 1 8 zero zero, six4ate 797zero option 3 and ask for Marco.
Ok I did some more measurements.
Measuring from the rim near the valve reliefs I get .058 deep.
If I measure from the quench pad it is at zero deck.
Going to the icon catalogue and using their specs. To get 10.4 compression with 60 cc I have to use the quench pad calculations of zero deck
Punching in my specs
Piston bore 4.08
Stroke 4.0
Connecting rod 6.123
Gasket thickness .027
Gasket bore 4.125
Head chamber 62cc
Piston volume 20.5cc
Deck clearance 0
Works out to 10.69 static
Working dynamic with the IVC at 68.5
Comes to a total of 8.329
I was planning to call icon today when their time zone catches up.
Thanks for all the help, but now I think I have it figured out and these dish pistons will work for what I am looking for
Thank for that clarification, it looks like OP figured it out too.
Using that .027 gasket at 5.9cc, I also get 10.69Scr, and with the ICA at 68.5..Mr Wallace says:
Static compression ratio of 10.69:1.
Effective stroke is 3.02 inches.
Your dynamic compression ratio is 8.32:1 .
Your dynamic cranking pressure is 168.22 PSI.
V/P (Volume to Pressure Index) is 159
This will work quite nicely with aluminum heads, but is generally accepted to be too high for iron and pump-gas.
However, this assumes that no part of the piston is above the deck, that the Q-pad has been milled, and you will have to recalculate/measure the bowl volume, after the machine work, if you want accuracy. With aluminum heads it's no big deal; you got plenty of room.
What is a big deal is running the pistons .027 from the heads. I'm no builder but that sounds awful tight. I might try it in my 367, because with just a 230* cam,and my very narrow gear-spits I wouldn't have to rev it past 5800 or so. I just like to hear it sing at 7000. I've been getting away with .034 +/- .0015, since 2004. But you you on the other hand have a monster-cam, which I have no idea where you're gonna need to rev it to,or how bad you're gonna abuse it, so Your results may vary.
And of course you are gonna have to check the piston to valve clearances, cuz at .600 lift and the pistons that high, there is a high degree of possibility that they are gonna get into eachother. And if you have to deepen the valve pockets, then that will change your Scr, which as you know,trickles down.
Measured .040 quench between head and quench. (Playdoh method)
Also barely any indentation with the valve clearance.
I have to do some pushrod clearencing Then I plan to double check with playdoh.
Reason for monster cam.
Solid roller cam
4.30 rear axle
Passon od 4 speed. 4th runs like I have 3.55's
28 inch tall tires.
It was a blast with the slightly smaller cam and w2s.
Also with a stroker motor I don't need to run the rpms to the moon.
Piston bore 4.08
Stroke 4.0
Gasket bore 4.125
Head chamber 62cc
Deck clearance 0
Thanks for all the help, but now I think I have it figured out and these dish pistons will work for what I am looking for[/QUOTE
If quench pad it is at zero deck you may want to rethink the Gasket thickness .027
  • LSA/ICL: 110/10
  • Abdc 51.5
And dynamic at 8.1
Will this work out?
Equals 9.5 dynamic.
You could do a hair better with a higher dynamic, yes ... I don't wanna say its going to be a an earth shattering amount....but imo you are just below the low end of "it'll run great and you wouldnt feel the diff hardly"....but i think you would rather have this difference. Idealy 8.8 dynamic is 'crisp a'licious' for that combo on pump piss.You want all the kick that fkr will give ya after popping off for those big port heads.
What trans and gear are you running with this combo?
I had the quench pad machined on my 408 combo .008 to make it all fit together with those pistons in 4.030 size, magnum block at 9.577 deck height. You could do something similar, like deck the block some, cut the quench pad some, use the .027 gaskets. Before doing that though I would degree the cam and check piston to valve clearance, and if you have to go deeper, call the piston people and find out how much you can go.
