ken5124
65 Valiant Signet
Just so I am clear,
to change the strut bushings on my 65 valiant, I will need to disconnect the spindle from the lower balljoint arm, remove the clip on the torsion bar, take the pressure off the torsion bar, and then after removing the lca pivot bolt, slide the lca back so the front bushing is accessable to change..
ANYTHING i AM MISSING??
Thanks!!
Thanks!!
