73dust340
Ok, I've been steadily fixing problems with my car and preparing it for Pittsburgh's humid weather. I will be sticking in a nice motor some day in the future (years from now). Now, I've read a lot of nice things about subframe connectors, but I'm not sure which type to get. I've got no problem welding them on, but for the time being I've only got a MIG with flux core wire, no gas, so it's a bit sloppy.
I've seen the kind that weld to the floors and the kind that go under them and don't weld to the floor. I'd like some input on which kind you guys think work best. I've seen some of you fabbed your own, but I don't have the tools or work area for that. I'm not too keen on welding to the floors, but if that's significantly better, that's what I'll do. I've got the tops of my floors all nice and stripped/painted and will be applying Damplifier sound deadener so If I must weld to the floor, now is the time. I'd like to skip subframe connectors for now and use the money on other things, but as I said, now is the time to weld if that kind of connector is much better.
