[WANTED] Subframe connectors
Hi Evilred73
I have a set of the "U" shaped brackets for the rear of the connector. All you need to fab is the bar to the front (easy part) I had a set made, Easy to ship, easy to make the bars any length you need and weld in!
I can send a picture or two :)
Frame connectors are super easy to fab. I used 1"x2" by 1/8" rectangular tubing and a couple pieces of 1" flat bar for the ends and made my own. The materials cost less than $30 but that was a few yrs. ago. Probably a little more now. Just a thought.
30x30 3mm wall i used with 70x40 flt plate on the ends, easy to do.
