diymirage
HP@idle > hondaHP@redline
Best i can tell, yesSummit owns Trick Flow right?
YesSummit owns Trick Flow right?
318 rods will handle 400hp all day long.The 68 truck block I have has a forged crank luckily but has the light rods , I do have an 89 truck roller cam truck block with hopefully the stronger rods but wonder if they are Worth resizing and balancing up with the KB 399 pistons
thats 100% vaid. probably cheaper to buy new if the stockers need work.Just ordered Scat rods , might as well keep everything fresh and dont want to go overboard with the stock stuff and possible extra crank balancing with added weight
i actually meant to quote your post. lol. yup! i agree. like that with most things these days.It’s been that way every time for me.
Awesome. Thanks for posting this.I bought a set of Summit I beam rods a couple weeks ago. Look like Scat to me.
Their stuff is on point. I recently used a scat rotating assembly (rods/crank) for the big block in my boat. Every measurement was perfect in every way. Other than cleaning the oil off from shipping, nothing was needed.13 years is a long time and things have changed. Hopefully Scat parts are still as good as they once were!
Have had my stock rods to 6800 many many times. The OEM is a forged rod and it is darn good, heavy duty next to other makes. The rod itself is heavy. A lot of weight can come off. That process is expensive and time consuming. This is where the next level rod is cheaper, easier & makes sense in that route. Otherwise, the power it can handle is pretty stout.Although back in the day we did all kind of **** with stock rods, today I would not recommend it. Why would anyone want to cheap out on one of the most important and stressed components in your engine. What is the total cost difference in the entire build. I'll be rebuilding a 340 soon that I built 25-30 years ago maybe longer. Used stock rods then but just never trusted it above 6000. It will not have stock ones now. That's just me.
I don’t see the re use of the OEM rod as cheaping out.
Yep the rod bolt size! And we sprayed a stock rod hi-comp, roller cam 440 motor to almost death and I would guess with the spray 900 horses, and the shifter stuck more than once in 2nd and who knows how far that puppy went, but my point is why redo the stock rods and save only a couple of dollars vs better new rods that haven't been twisted to 9000 grand. Anyone out there with a current price on rebuilding the rods and new arp bolts. What's the total cost of doing the motor? Just a guess min. 5k so saving 4%. So, in my world saving 100-200 bucks or so when rebuilding a motor is cheaping out.Exactly. Using OE rods certainly isn’t cheating out because it’s expensive to do them.
I turned OE rods 7500 for a long time and never hurt one.
The weakest link is the 3/8 bolt and nut rather than a 7/16 cap screw. Other than that, the OE SBM rod is pretty bitchin’. Oh, and the cost lol
I had a set redone last year - ARP bolts fitted, resized and set up for floating pins, $300 to the machine shop & $100 for the arp bolts.Anyone out there with a current price on rebuilding the rods and new arp bolts.
Was there a rod weight in the box?I bought a set of Summit I beam rods a couple weeks ago. Look like Scat to me.
