Summit engine mounts
You can use biscuit mounts but itll lower the motor about 2" below the thick old mounts.
First off, Summit doesn't make anything. Even the stuff with their name is somebody else's product. You can use the 273 brackets and mounts, but you will need to shim one of the mounts.
Thanks guys I have my engine in the car with the 273 mounts shimmed it just makes me nervous and would like to change but I don't want to spend the money on schumacher
Lots of guys have run shimmed mounts for years. If the bolts are tight you won't have a problem.
