concrete52
Active Member
got a super 6 set up - rebuilding me a 225 slant 6 - got me a 75 dart swinger - now this carb that i have is stamped st. louis - carter 0-2543 - now when it comes time to rebuild the engine which will be a mild build - the focus on the carb i am needing to understand - certain things have been done not only to the moters but carburation for sure because of smog emmissions - the so called lean burn - anyone can tell me what to really do with this carb to ensure proper function - thanks
