I can see the airflow. ha ha can you
Do tell where the hot air is coming from!I can see the airflow. ha ha can you
I think what is getting past you is that those guys are giving "error on the side of caution" advice.Mike has done it, seen it, lost power, so don't do it. I think Jim agrees. they both can see the air.
Well, I`m going to have to get another intake after I get the fish lined out. Curious now. Will do an a b a test , maybe this summer. those corner bulges sure looked in the way of a 1200cfm throttle bodys' injectors, and the way they (8) are pointed. not doubting the 2 experts word !I think what is getting past you is that those guys are giving "error on the side of caution" advice.
They chased bench numbers to the max and it bit them. Extreme case perhaps.
To me...this is like 15 years ago where the "pros" tell the "novices" better be safe than sorry and leave the porting to the "pros".
Sometimes "some people" only see this way or that way....forgetting the middle, no low volume...just on or off. You can lightly blend those areas and gain power, but you can also easily go too far and go the other way.
You may now resume your humorous curtailing....
LOLWell, I`m going to have to get another intake after I get the fish lined out. Curious now. Will do an a b a test , maybe this summer. those corner bulges sure looked in the way of a 1200cfm throttle bodys' injectors, and the way they (8) are pointed. not doubting the 2 experts word !
I used to think where the injector sprayed was a major consideration as well and even fabbed up the manifold in the picture with a very high and angled injector location.I couldn't stand the thought of the injectors firing basically into the floor of the port. Did it work? Yes. Did it work better than in the conventional location? Who knows?--doubtful to be honest. When Jon Kaase was developing his winning Ford Mod motor in EMC 2013 he used a Cobra R manifold and commented that some of his testing involved firing the injectors upside down into the bottom of the lid! It worked VERY well he commented.
In the second picture is a shot of the plenum and yes I removed the large radius at the tops of the runners. I think it contributed to a loss in midrange power actually. Like its already been said--Nobody here is really an expert, you just have to weigh the pros and the cons and make a decision. J.Rob
