EFI, so it will be a dry manifold if that matters....thanks for any info!!
This. Been there, done that.Dont do it. Just smooth off the rough edges and leave it there. TRUST ME.
And this is true to a point, just like there are gains in head porting, you don't just go and grind out everything to be as big as can be and out of the way as possible.Grind it out. You've GOTTA know way more than those stupid intake manifold engineers.
Mike is right. I've tested it on the dyno!Dont do it. Just smooth off the rough edges and leave it there. TRUST ME.
my 1200cfm throttle body is so big compared to that area on my intake I had to take them out and re shape the radius-opening up the corner runners, which are the weak ones on a torque 2.. (used it for hood clearance and staying away from dual plane for the fuel inj. will see next summer I hope. I built it mushy down low, hoping to get some traction, but so far it feels like it comes on like gang buster, haven`t had it over 5000 , yet. still working bugs.And this is true to a point, just like there are gains in head porting, you don't just go and grind out everything to be as big as can be and out of the way as possible.
ah come on Jim ....you mean to seriously tell me you bolt those on ootb every time, I don't buy that ...especially from you!Mike is right. I've tested it on the dyno!
Well according to the tone I'm reading in this thread...you did wrong and it should run like ****.lolmy 1200cfm throttle body is so big compared to that area on my intake I had to take them out and re shape the radius-opening up the corner runners, which are the weak ones on a torque 2.. (used it for hood clearance and staying away from dual plane for the fuel inj. will see next summer I hope. I built it mushy down low, hoping to get some traction, but so far it feels like it comes on like gang buster, haven`t had it over 5000 , yet. still working bugs.
I have done back to back to back to back tests where I used a gasket matched stock Victor intake. Then smoothed the bulge area like Mike said. Then installed the 2" spacer on the smoothed throat. Then we ported the bulge out and blended the opening into the intake runners and made some more dyno pulls. And finally put the 2" spacer on the ported intake and pulled some more.ah come on Jim ....you mean to seriously tell me you bolt those on ootb every time, I don't buy that ...especially from you!
HAHA We have both fell victim to or over active brain. Its amazing how much power was LOST from removing it, and it was across the entire rpm range, bad bad bad. I will never do it again i can tell you that.
I'd listen to Mike (MRL) unless your talented with a grinder and understand air flow. As well as being able to afford not just 2 intakes but the dyno tested my of the first after mods, then again after the 3 mod and the forth mod, the 5th....
My point being money to prove what has been discovered already.
Most times, intake that respond to porting are done in the manor I mentioned. And that's a "IF" mind you.
What? Re Weld the intake back to the way it was? Duplicate the bulge? Are you kidding me?!?! LMAO!
You sir, are very funny!
LMAO!
Oooooo-kay
